CNC Coating Machine
Discussion in 'Other Builds' started by Vegard Humlen, Dec 1, 2018.
  1. Vegard Humlen
    Vegard Humlen published a new build:
  2. dregalia
    dregalia New
    Would you go into detail about how you have created the pump/liquid distribution system?
  3. fernando palacio edreira
    great job!!!!!!, im thinking about creating any similar but at the moment didnt know nobody that works with vmatic....culd you tell us any:(:(:(:(thing more about the project????
    tks a lot friend
    Fdo
  4. Vegard Humlen
    Hello, sorry about the late reply. I have been offline for a while.
    I have two pressure tanks with two parts of liquid. With air pressure the liquids are pumped up to the valve where the ratio of each part is calibrated. From there both parts go in to the static mixer. The Valve comes with a controller who open and close the valve with air pressure. I can record a short video next week and upload it when it is runing. If you want I can relay you to my contact in Vmatic. I gave them technical data of my fluid and the sorted out all the parts needed.
  5. Vegard Humlen
    What kind of fluid are you planning to use? I will soon build one more with higher viscosity one part fluid. More or less a glue dispenserfront.
