CNC Bed, whats the best way to get everything level
Discussion in 'CNC Mills/Routers' started by Alan Foster, Sep 13, 2018.
  1. Alan Foster
    Hello I have an Ooznest, 1.5m x 1.5m bed and its a brilliant machine which I use in my business for cutting all sorts of stuff, but we need to get the bed level, as we have used 15mm MDF as spoil board, and we have a Chinese spindle with a 6mm collet, but cant find a good flycutter to get it absolutely flat which we need to do to do some rebating.
    Could anyone recommend a flycutter that would do the job, as we have been trying allsorts of wide router bits but don't know which flycutter would be best.
    thank you
    Alan
  2. Kevon Ritter
    Kevon Ritter Veteran
    You mention that you have been trying different cutters. What were they? What were the results? I use a 7/8" planing or "cleaning" router end mill.
  3. Alan Foster
    Just the wide wood cutting bits that you can get for a normal router, i think the widest was 12mm, it did take a couple of mm off the bed, but i do get a bit of flex on the gantry with it being a 1500mm x 1500mm, i just need something with a 6mm shank that would do the job if anyone has a link
    tia
    Alan
  4. Kevon Ritter
  5. JustinTime
    JustinTime Journeyman
    You can get even bigger bits than the 7/8" if you want. Search 'Cleaning Bottom Router Bit' on eBay.
  6. joe williams
    joe williams Well-Known
  7. Techvette
    Techvette New
    I use a 1" "surfacing" bit:
    https://www.amazon.com/gp/product/B071748JQN/
    It's not cheap at ~33 USD, but it's a great bit. The only real issue I had was router "lines" on the board, which turned out to be the result of a very slight angle between my Z axis and the table. Basically, the Z - and therefore the bottom of the bit - were at a very slight angle relative to the X axis (on my machine, X is the thing that the router carriage rides on). It took some thinking to work that out.
  8. CNCMD
    CNCMD Journeyman
    While everyone is recommending surfacing, you should consider tramming the spindle in as well.
    GrayUK likes this.
  9. Techvette
    Techvette New
    And that's the first time I've encountered the phrase "tramming the spindle." Thanks - the Tubes provided helpful explanations. :)
    And it looks like Joe and I posted the same product link.
  10. Gary Caruso
  11. CNCMD
    CNCMD Journeyman
    In short tramming the spindle is adjusting the spindle so that it is square to the table at all sides. What I like to is take a 1/4" steel dowel that is about 3" long, put it in the spindle. Then using a square sitting on the work surface check gap of the square to the dowel. Do all 4 side of the circle, lol, if you know what I mean, and see what the results are.
    GrayUK likes this.
  12. Richard Wisniewski
    I use a dial indicator
