Chamfer in openbuilds cam
Discussion in 'CAM' started by Hykr3n, May 6, 2024.
  1. Hykr3n
    Hykr3n New
    Is there an easy way to do chamfer using opb cam?
    how do you offset your em?
    Lie about the endmill diameter and use a V-Bit :)
    Endmill diameter / 2 = offset
    Cut depth and offset determines how much you are chamfering. Have a play, its a hack, but it works. Couple test runs and you'll click it
    Giarc, JustinTime and Hykr3n like this.
