Cartesian Style Build UK
Discussion in 'CNC Mills/Routers' started by Steve Hall, Nov 8, 2021.
  1. Steve Hall
    Yes, all are operational and come up with the alarm window on each activation, i then have to turn off the alarm. But as soon as a try to home it, it goes past the limit switches?
  2. sharmstr
    Any chance you have the switches mixed up? Homing goes Z, X and then Y. If, for example, you have the X switch plugged into the Y port and the Y switch plugged into the X port, then homing will never find the X switch.
  3. Steve Hall
    Embarrassingly so sir, Embarrassingly so. I have had them on and out that many times I have mixed them up. So when it performs the homing test, it is only test one switch at a time as well?
  4. sharmstr
    Dont know what you mean by homing test. Glad you figured it out though.
    Steve Hall likes this.
    Probably also wiring, or if you wired it to the Coolant control, remember to turn it on from the Tool On menu
    sharmstr and Steve Hall like this.
  6. Steve Hall
    Just liked to say 'thank you' to everyone & that the machine performed the home sequence last night, that's all i had chance to do.
    So a good clean up and hopefully will get to the ubiquitous 'hello world'
  7. Steve Hall
    I am going to use Easel Pro as i find it quite intuitive to use -
    My Main cutters to start will be 3.25mm round nose, upcut and downcut quarter inch and quarter inch 60 degree V Bit 4 flute
    Cutting MR MDF any recommendations on speed and feed rate please?
    As a newbie I have no idea if the pre-set speeds are good or not?
    Also, just been trying to google the speed settings for the Dewalt 262
    What are the rotational speeds at 1, 2, 3, 4, 5, 6?
    WoodKnot
    #37 Steve Hall, Dec 6, 2021
  8. sharmstr
  9. Steve Hall
    Still cannot find the coolant control Peter, where should I be looking?
  10. Steve Hall
    Hi, build complete, how do I change the status, will add a few images later! Very pleased
  11. Steve Hall
    So, did the hello world and thought, OK, time to try one of easel designs I have made.Then my problems started again. Easel does not seem to connect to my machine for some reason. I have installed both pieces of software on a Windows 10 Pro machine.
    I tried exporting the project into openbuilds and got an error code, which I should have taken an image of, but it was getting late and needed to walk the dog!
    Anyway, as usual, any tips or pointers would be very much appreciated.
    WoodKnot
  12. sharmstr
    In OpenBuilds Control, click on tool on, the click coolant on. Not sure if you can do this from easel.
    Need to see the error message in order to help.
  13. Peter Van Der Walt
    M9/M8 in gcode. Or the Tool On menu in CONTROL
