CAM: Laser and CNC operations not generating G-CODE
Discussion in 'OpenBuilds Bug Report' started by sergiomajluf, Feb 25, 2021.
  1. sergiomajluf
    sergiomajluf Well-Known
    As of 2020-02-25 cannot generate g-code for Vector Path operations (no offset, inside, outside), nor CNC operations. Works OK for generating raster fill of vector shape.
    Reports no errors, but produce gcode with only intro code, no geometry inside.
    Attached workspace and output gcodes.
    Will check
    Do you have a workspace export of a CNC operation that doesn't work, that in particular tests fine here
    Fixed bug for laser operations.
    Force refresh (CTRL/Shift + F5) to get the latest UI in your browser
    #3 Peter Van Der Walt, Feb 26, 2021
    sergiomajluf likes this.
  4. sergiomajluf
    Thanks! it works OK now
