Cam for tangential knife.
Discussion in 'CNC Mills/Routers' started by Jonny Norris, May 22, 2015.
  1. Jonny Norris
    Jonny Norris Well-Known
    Any one know of a cam with tangential knife function? With Mach 3 post processor.
    Jon.
  2. Jonny Norris
    Okay found out this can be done by mach 3
  3. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Just a tip...
    If using Mach3 it is best to avoid G2 /G3 arcs. If that is not possible then create the toolpath with a lead-in with the same radius as the arc for all circular cut-outs.
    (There is basically a 'never to be fixed' tangential control bug which will rotate the tool whilst lowered into the work - this does not cause problems for thin material but can be a real pain when cutting thicker stuff).
    Tweakie.
    Jonny Norris and Joe Santarsiero like this.
  4. Jonny Norris
    Good tip, Thanks Tweakie, I would have otherwise found out the hard way im sure.
