CAD file for V-Slot Actuator End Mount
Discussion in '3D printers' started by Nerven Cid, Oct 20, 2014.
  1. Nerven Cid
    The Sketchup file can be found on the files tab on this page. Belt and pulley information can be found here.
  3. Nerven Cid
    Thakyou for your answer...
    By chance, do you have a stp file or a plane with measures? i don't have/know sketchup....
    #3 Nerven Cid, Oct 20, 2014
  4. Rick 2.0
    Nope. Sketchup is free however (download) and is really not that difficult to pick up on.
  5. Nerven Cid
    Hello again and thankyou for your answer:
    I analyse the draw in the sketchup files and i could'nt find some constraints...
    Can you tel me the value of that measures?
    #5 Nerven Cid, Oct 20, 2014
  6. Rick 2.0
    All but one of the dimensions you are asking for can be found through simple subtraction from values already given on the drawing or through logical reasoning. The one that can't, I don't have an answer for but if it is absolutely critical, please contact the shop for a measurement.
  7. munchit1
    munchit1 New
    dowload sketch up,
    use the arrow tab in the menu bar to select the part...
    select the part again to get it alone if you want to, then orbit till you see the bit you want, click on the tape measure and measure it.
  8. munchit1
    munchit1 New
    if you get multiple parts 'stuck together' ''exspode'' it, it'll seperate them.
