C-Beam X-Large Motor settings
Discussion in 'CNC Mills/Routers' started by Goran crno, Feb 8, 2017.
Tags:
  1. Goran crno
    Hello all.
    I hope someone can Help ....please..... I'm getting Crazy
    I added some screenshots of the motors and setup.
    First of all I love my machine... but I have some problems getting my motors to run smooth after cconfiguring.
    Let me first explain where I bought my motors and my setup.
    C-Beam X-large fro Tronixmaker Belgium
    Motor, Controller and board from German Ebay:
    2.5Nm Nema23 Schrittmotor CNC 4 Achse 5A TB6600HG Endstufe Professionell 36V 10A
    2.5Nm Nema23 Schrittmotor CNC 4 Achse 5A TB6600HG Endstufe Professionell 36V 10A | eBay
    Software: Mach3
    I received a PDF from the manufacture to use these settings.
    3rd_5Axis_Breakout_Board_Main_Settings_En.pdf
    Had some problems first with the motor running smooth and loosing steps in Mach3......but after reading some good tutorials I found it was related to windows GUI setting to classic....( good tip to all other users).
    Set Default Units for Setup: in MM's
    In Mach3 settings Motor tuning and setup:
    Steps per: 750 Velocity: 100 Acceleration: 15 Step Pulse: 5 Dir Pulse: 5
    I tried to increase the Steps per: to 2000.......but than the motor jerk and run crasy.
    when jogging using the MPG Jog in Mach3 or on the Keyboard of the Computer....all Motors run like a charm...real nice.....so fare so good.
    Now when I try to calibrate my Machine.....that it runs accurate in mm's...it happens..........the Motors getting really slow.
    I go back in the Motor tuning and setup in MAch3....the Steps per ( was 750) changed to like 24 steps per...and it runs sooooo slow now!!
    Now what I do wrong????
    Something with the controllers....wrong jumper settings???
    Strange is that all runs smooth when I jog the MPG in Mach3.....
    I hope that someone has a good tip...configuring my setup.....
    Thank you all.
    #1 Goran crno, Feb 8, 2017
  2. Goran crno
    Hello
    I found the problem. In was in the board settings and the jumper from the controller.
    Greats
    Goran
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
