C-Beam questions for PCB milling application
Discussion in 'CNC Mills/Routers' started by techfreakz, May 16, 2016.
  1. techfreakz
    techfreakz Well-Known
    Hello,
    Great work on the C-Beam @Mark Carew - this is going on Santa's list!
    A few quick questions that I'd really appreciate anyone's input on:
    1) Has anyone used the C-Beam to also mill PCBs?
    2) If so, do you have a preferred router/spindle? The commercial LPKF machines I've used tend to have smaller spindles, but with higher speeds (60,000+ rpm).
    3) How has using the anti-backlash nut improved the machines performance in practice? Are the machined edges more defined?
    4) Should I consider using a ball screw instead to reduce the friction and backlash or would it be difficult to notice the difference in the finished PCB/product due to other contributing factors?
    5) Has anyone tried the TinyG controller with this machine?
    Thanks again!
    Alex
