C-Beam/Plate Measurement Request
Discussion in 'General Talk' started by Dean Murphy, Mar 16, 2016.
  1. Dean Murphy
    Was just wondering if anyone could measure or has the measure of the total height of:
    C-Beam plus mounted universal Gantry Plate.
    I know the C-Beam is 40mm, and the Gantry Plate is 3mm, but was wondering how much height is added when mounted.
    Thanks for any assistance!
    Dean
  2. Kyo
    Kyo Veteran
    Hello Dean,
    Just under 46mm (45.843mm ) according to @Mark Carew C-beam Sketchup model. But it really depends on what spacers you end up using for your wheels / nut block as to how high off of the C-beam the Plate will ride.
  3. Ronald van Arkel
    To do it by head and without the drawing:
    C-Beam till half the wheel: 30mm
    Half wheel height: 5.5mm
    Shim: 1mm
    Spacer: 6mm
    Gantry plate: 2.93mm
    Total: 45.43mm
    Screw head is about 1.55-1.60mm in height.
    So yes, 45.843 is close enough ;).
    -Ronald
  4. Dean Murphy
    Thank you both very much -- that is exactly what I was looking for!
    Dean
