C-Beam Machine XLarge
Discussion in 'CNC Mills/Routers' started by Moag, Jul 31, 2016.
  1. evilc66
    evilc66 Journeyman
    I don't think I would reference a very grainy "spy shot" as how things are going to be built. If anything, the last picture that was posted of an actual assembled machine (assembled according to the instructions) is what you should reference. That clearly shows the Y-axis C-Beams facing down, and in that situation, the cross beams will reduce the travel of that axis.
    Also, the official description of the functions of the machine posted on the build page state that the C-Beams are flipped to keep chips away from the screws. You will also note that they are posting the build instructions as we speak (not complete at the time of this writing), so that will show you without a doubt the orientation of the Y-axis C-Beams.
  2. dean knipping
    @evilc66 is correct...I looked back at everything and yes you would lose width of the V-Slot x2 for the Y axis assuming they travel the entire length of that axis.
    an easy modification for that would be to use the C-Beam Shield and I am surprised that wasn't done since it would be fewer parts, less complicated but possibly a little less rigid and I think rigidity is going to be good here
  3. Rick 2.0
    You'll note those in the photo are laying loose and not in their final position.
    Think through that idea a bit further. The shield would have to be above the gantry plate which then makes it difficult to attach the platform board. Also any debris that did work its way down into the slot would be pretty much impossible to remove without substantial disassembly.
  4. dean knipping
    hhhuummmmm....I hate being wrong :banghead:
  5. dean knipping
    new thought here....if you have 2 lead screws, even if they are being mirrored like they can in the xPro, what's going to keep them from racking? I know they aren't going to be perfect and would assume over time the small differences would add up and could cause issues
  6. GrayUK
    The whole principle of "Stepper" motors, is that they will move in, "pre-determined steps", of an equal measurement, set by yourself. There has to be a high degree of precision in the screws.
    That is why you don't go down your local hardware store and pick up a metre of threaded bar. That is also why you have multi-start threading. So if you have racking as a problem, and it's not your stepper motors, drivers, or main board, doing strange things, then you probably have a faulty screw.
    Gray
  7. Charlie B
    Charlie B New
    Hi guys especially Mark and Moag I am completely new to to this forum and have learned so much in the past weeks reading through and looking at different build projects. I have been wanting to build a CNC machine for years and now is the time to dive in. I was loking at the basic C-Beam but then came across this X-Large project which is ultimatey what I would have developed the basic model into, to meet my hobby needs, building models and kids toys from wood. My question is, is this X-Large version too much for a complete novice? What would be the estimated cost of the kit bundle plus electrics? Looking at this as a winter project so hopefully it won't be too long to release date. I am ok on the mechanics but would probably be looking for help in the electronics department no matter what project I end up building.
  8. jctb2
    jctb2 New
    Newbie here, just purchased the c-beam bundle a few weeks ago. Any plans for an upgrade bundle from the std c-beam to the new XL?
    snokid and Charlie B like this.
  9. Traxxtar
    Traxxtar New
    After more thinking....you could use the CBeam Riser Plates and the CBeam Shield to provide protective coverage of the screw. If so, it would appear that you could flip the CBeams over without sacrificing Y axis movement distances. Then, you could lay those X axis supports horizontal as I menioned in the beginning. Or is there some other reason it couldn't be done this way?
  10. evilc66
    evilc66 Journeyman
    Re-read the last sentence of the post you quoted. That's why they are upside down. Using the shield keeps debris directly off the screw, but not out of the actuator. Mounting them upside down keeps debris out of everything.
  11. Traxxtar
    Traxxtar New
    Mounting them upside down prevents you from being able to flatten the X axis cross members and lowering and strengthening the rigidity of the overall frame which is what I was hoping to achieve. I think a good shield would suffice and allow them to be mounted as desired. The shield sold by OB might not cover everything, so some additional fabric, rubber, or other materal might also be needed. Time to get creative I suppose.
  12. gatech77
    gatech77 New
    Have not seen any activity on this thread in almost a week. What is the status of the build kit?
    Thx.
  13. FireHaus
    FireHaus New
    Any update on parts list and/or bundle price? This is exactly what I have been looking for!
  14. Charlie B
    Charlie B New
    Hi Moag's just uploaded the latest build specs yesterday, awesome detail
  15. Wylie
    Wylie New
    Hi,
    I to would like to know if a kit/bundle will be coming for this.
    I have put my design on hold, to wait and see.
    Steve
    PS this bundle sound like it will be very popular, so can we hurry this up a little bit.
  16. Mark Carew
    Moag has been working tirelessly on recovering some of his manual lost in a computer crash! Hes got it done now and it looks fantastic!
    Almost there guys we are shooting for a release very, VERY soon! :thumbsup:
    GrayUK likes this.
  17. Moag
    Moag Veteran
    Cheers Mark, please excuse the typos, I guarantee there's going to be some.;)
    :D:thumbsup:
    Oh, guys don't forget how much work and designing Mark has put into getting this Bad Boy to you.:thumbsup:
    GrayUK and Mark Carew like this.
  18. dean knipping
    @Moag Yikes on the computer crash...I have been fortunate to only have a couple of those and have found Google drive is a godsend since I can keep all my important docs there as well as a thumb drive. Looking forward to the release of this beast
  19. MaryD
    MaryD OpenBuilds Team
  20. Bad Sequel
    Bad Sequel Well-Known
    Yay!
    Moag and Mark Carew like this.
  21. Makerparts
    Makerparts Well-Known
    Is a guide available on how to wire this up ?
  22. Mark Carew
    GrayUK, Kyo, Moag and 1 other person like this.
  23. David the swarfer
    "if you only have one copy of a file, you only THINK you have the file"
    backup your backups....
  24. Traxxtar
    Traxxtar New
    This build looks absolutely fantastic. The build instructions are superb. This is on my Christmas wish list and my wife will have all the links and instructions to buy for sure. Hopefully, my sweet little Santa Claus will take heed and be so kind. ;)
    Now...I just need to win that controller package naming contest!!
  25. MaryD
    Santa Knows ;)
  26. Mark Carew
    Hey guys here are a few files for the acrylic sides. - dwg file attached as well. :)
    Bad Sequel likes this.
  27. Jean-Sebastien Stoezel
    Hi, I was just about to order a Shapeoko (like literally I had clicked on checkout) when I came across this machine.
    I am not torn between a Shapeoko and this the C Beam XL, and I am hoping I can get an objective opinion on which machine I should get.
    I'd like to get a CNC router to build small aluminum enclosure to house electronics. By small I mean that the boxes will not be any bigger than than 1" x 1/2". My wife wants to use the CNC router to create artwork and wood signs.
    The Shapeoko is a bit limit in size at 16"x 16", the C Beam is much wider (though a bit shorter). The dimensions seem to be in favour of the C Beam as my wife would be able to make wider signs.
    The C Beam has limited vertical action though, 1" shorter than the Shapeoko.
    The Shapeoko comes ready to assemble, everything is bundled with it. I'm still confused by what really needs to be ordered electronic-wise for the C Beam. The motor option is nice, but what about the driver? Controller board? Power supply?
    Then there is the price. The Shapeoko is almost identical price (to me in Canada) as the C Beam with the option. The C Beam gets more expensive as you add drivers, controller and power supply. I guess I could also go with an electronic combo from eBay (including the motors), which would bring the price right down to the Shapeoko.
    Last is the shipping option. There's an importer for Shapeoko in Canada and I get free (!!!!!) shipping for the Shapeoko, which I'm quoted $176 from the openbuilds website. This adds quite a bit to the final price.
    While I'm the only one who will be able to eventually make up my mind, I'd like to get an opinion (preferably objective, I know this is an openbuilds forum) on the 2 machines I am considering.
    Further, if somebody is able to provide a complete electronic package that would be very competitive price-wise, to bring the C Beam option close to the price of the Shapeoko.
    If I were to place an order now, when would I receive the C Beam?
    Regards,
    JS
  28. Moag
    Moag Veteran
    ;)Yes yes. It was just a little more complex than just losing a file unfortunately, my biggest problem is being unorganised I thinko_O, searching for way too many image files, scattered all over the place is a headache for me at the best of times, "I know it's there, but where did I put that picture", with about 4TB of image files split between four 2TB external hard disks, with a heap of build renders saved to 360A (cloud storage), so actually I just lost the build page manual side of things, not the pdf, because I was just saving edits, but not submitting the build; with only a couple of uploads to go before hitting submit when the server decided to have a backup glitch a week or so back and all gone. Oops:banghead: The super fast :sleepy: copper telephone cable internet in this part of the world, that they call broadband doesn't help.:rolleyes: All good now that I can get into playing with this fun machine and loving it more every time I can sneak to the shed for a play.:thumbsup:
    Thanks, @Traxxtar for the plug mate. It would be such a sweet machine with "the controller of many names".;) Hoping Santa gets your note. Please, Santa me too.:D
    Uploaded the to the Build Page Mark.:)
    @Jean-Sebastien Stoezel , just get the C-Beam Machine XLarge, if you intend it to be more than a hobby and want a stronger machine, but I can't help being a tad biased;)
    Sounds like you need a small machine, like their Nomad or Openbuilds, C-Beam Machine Plate Maker here unless you want to cut out a heap of small boxes all at once, then the C-Beam Machine XLarge would be like a small factory. While your Wifes 2.5D carved pieces and signs, would be better suited to one of the belt driven OX style builds with faster speeds through soft materials, but again if she needs greater accuracy for her Art pieces and to cut harder material the C-Beam Machine XLarge would be ideal choice for her.
    But please have a close read of the build page, to see if it's something you both could make and work with together. :) While you're here have a good look around at the other fantastic builds and huge knowledge base of this fast growing community.
    Moag over and out to the shed.;)
    Mark Carew and David the swarfer like this.
  29. MaryD
    The XLarge built in the earlier spy photo was built by a novice and he completed it in what would be less than a weekend. The build manual is so detailed, I think it will be fun for you.
    Mark Carew, GrayUK and Moag like this.
  30. Moag
    Moag Veteran
    ^By the way, thanks, Charlie B;)
