Building my own CNC
Discussion in 'CNC Mills/Routers' started by Adamski, Aug 23, 2017.
  1. Adamski
    Adamski New
    HI ALL
    Im in Scotland, UK
    I want to build my own CNC, This
    C-Beam Machine XLarge Specs
    What i want to know is can i make this a custom size? for a workng space of around 500mm x 15000mm?
    Anyone know where i can get the custom made parts for this working size?
    Rails etc?
    I can do a stand and assemble etc​
    • X Axis Travel - 750mm (29.5")
    • Y Axis Travel - 330mm (13")
    • Z Axis Travel - 2" Actual working depth ~1"
  2. Gary Caruso
    15000? or 1500?
    no custom parts needed just cut the rails to the length you need. stock 1000x1500mm v-rail setups give about 820x1270mm cutting area.
    Just don't get the Kit and get the plate set you want with the V-rails.
    Or
    got to Ooznest and get the kit any size you want
  3. Ryan Lock
    Ryan Lock Veteran
    Hi,
    I am afraid for the C-Beam the biggest would be 1000x1000mm, screws whip if you go any longer
  4. Gary Caruso
    Oh Right I read C-beam and think Ox LOL.. for that big Dual-belt Ox is really the only reasonable way, without going to 12mm screws or rack and pinion $$
  5. Adamski
    Adamski New
    Hi
    WANT TOO BUILD A 1500mm x 750mm- 1000mm Ox CNC steel with NEMA34
    I seen this kit, but i already have the bits below
    http://makersupplies.dk/20-ox-cnc-kits
    I guess ive a lot of reading up to do, i have already ordered a NEMA34 Kit from China and HAVE already from the UK
    SEEN BELOW DUDES
    What Kit is it i need to finalise my build?
  6. Adamski
    Adamski New
    P.S. I hope the steel works okay and is solid enough with the nema34? and aluminmum sides?
  7. Gary Caruso
    why nema34? it's overkill for this size cnc
  8. Adamski
    Adamski New
    I got the package deal from China and as im a rookie with all of this i thought go heavy duty and if its too much reduce it too the lesser nema
    Hope they aint to heavy for the frame?
  9. Gary Caruso
    Weight isn't the issue, the nema34 size is much bigger and will not fit on the standard ox plates which are all made for nema23.
    nema23 makes plenty of torque for an ox, enough to do damage when it crashes.
    More torque isn't always better, you reach a point where other things are limiting performance, such as overall stiffness, and the drive system (such as belts or acme screws).
    these are what i'm using and i have not wanted for more power.
    nema23 269ozinch
    Which package deal did you get? the one in the pic? then you want nema23
  10. Adamski
    Adamski New
    When the boards and Nemas come im going to explore with them, test them etc, i will take your advice and most likely sell the34 and get the 23
    (EU Free, No taxes, USA Free, fast ship) 4Axis Wantai CNC Engrave Mill Nema 34 Stepper Motor 1090oz in,5.6A DQ860MA, 3D Printer-in Stepper Motor from Home Improvement on Aliexpress.com | Alibaba Group
    Ive yet to buy the frame
    OX CNC Full Kit | Everything For A Hobby CNC Machine
    i got the other bits of ebay
    EXTRA Z CLEARANCE OX CNC ROUTER GANTRY PLATE 28 V SLOT XTREM WHEEL 13 ECCENTRIC
    The frame is what i really need the Black one 1500 x 1000 i think it is
    I will start to add pics etc when the items come
    thanks for the advice
