Building a MEGA PRINTER, what do I need?
Discussion in 'General Talk' started by ChickenStilettos, Jun 11, 2019.
  1. ChickenStilettos
    Alright, so I want a 25x25ft 3D printer for printing concrete statues.
    I've dabbled with small 3D printers at college with CAD and am ready for a build my own model.
    Can you give suggestions and list what items I may need for an over-sized 3d printing head, tubes, actuators, material strength, etc?
  2. Giarc
  3. Chad Barton
    Think aluminum stage trusses
  4. dprice
    dprice New
    I think you would have to start with your concrete mix to come up with something that is fluid enough to pump but stiff enough to maintain a shape when extruded....and can be mixed on demand and is fast setting. The mix design will dictate much of the equipment design. In other words, I think your "concrete" is going to need to behave much more like a 2-part fast-set epoxy (with filler?) where you utilize a mixing nozzle for placement.
  5. Chad Barton
    It’s technically not concrete it’s Portland cement mixed with sand and 100% polypropylene concrete and cement mortar fiber. If you use white Portland cement then you can add dye to the mix to make just about any color you want.
  6. Chad Barton
    The polypropylene fiber is used for anti cracking then get a concrete mixing station with a built in pump and start playing with mixtures I’d guess 50/25/25 mix 50% Portland cement 25% sand 25% fiber would be a good place to start the viscosity of the cement would all boils down to how much water you’re using in the mix.
  7. Chad Barton
    Also axis speeds of 7.00 inches per minute and use stepper motors to drive your axis’s on a gantry style machine built out of aluminum trusses
  8. Chad Barton
    I’m a CNC machinist working for a shop that builds automated machines. NEMA 34 12nm stepper motors are about perfect for the application until you upgrade to printing houses because of the weight of you printer itself.
