Build Plate Aluminum or Stainless Steel
Discussion in '3D printers' started by JCPhlux, Apr 3, 2015.
  1. JCPhlux
    JCPhlux Well-Known
    I have been designing a new printer and am about to order the build plate. I was going to go with Aluminum but was wondering why not use stainless steel.
  2. JCPhlux
    JCPhlux Well-Known
    No opinions to be had :(
  3. Jason Farley
    Cost most likely. Stainless is expensive and probably not necessary in the application.
    I am not familiar enough with the needs of a heated bed for 3d printers but thermal conductivity might be and issue as well. AL is a much better conductor of heat.
  4. DiggerJ
    DiggerJ Journeyman
    What Jason said...
    The concept behind them is to have a solid, accurate, efficient substrate to more evenly spread the heat from the pad. Stainless might qualify in 2 of the 3, but Al will be more efficient with the heat spreading.
    #4 DiggerJ, May 1, 2015
    feenix3k likes this.
  5. Joe Santarsiero
    Joe Santarsiero OB addict
    Have you considered glass?
  6. DiggerJ
    DiggerJ Journeyman
    oops, I thought he was talking about heat spreader, yes, heater, aluminum heat spreader on top of that, and a piece of boro on top of that.
