Build my first CNC Router
Discussion in 'General Talk' started by Robert Selvey, Apr 16, 2017.
  1. Robert Selvey
    New to cnc routers, looking for some help. I would like to but a good machine size to be 4x4 or 4x5 from what some have told me mach 3 is the best software to run. I would like to know if someone could help me out with a complete list of parts I would need to put one together. I don't need a PC just the cnc router parts everything to complete the job. I have looked all over open builds and all the ones I have seen don't see all the parts, if someone has some time it would be great if you could help me thanks.
  2. Giarc
    When you look at a build, click on the parts list tab. You can make pretty much any one of them the size you want by increasing the length of the X and Y beams. These two have detailed build manuals and videos: OpenBuilds OX CNC Machine and C-beam Sphinx
    DenD likes this.
  3. Robert Selvey
    I am so lost, this guy wrote me up a list of stuff for a complete build. I want a good decent machine 4x4 4x5 size. Even with his list I'm still not sure what to buy.
    4 x of 16mm or better linear rails, 2 being 3000mm long, 2 being
    1500mm long
    5 mod1 gear rack, each 1500mm long...they but up to each other for
    seamless meshing.
    1x 80 x 100mm x 1500mm extruded profile aluminum, 80/20 sells
    these on ebay
    1 400mm c beam axis complete with ball screw and related hardware
    2x nema34 with 3 to 1 speed reducers, 1 nema 23 with speed
    reducer, 1 regular nema 23 fo the z axis if you did not get it included
    on the c beam z axis.
    2 power supply for the nema 34 (36v, 10 amps each) 2 36v power
    supply for the nema 23's
    1 3 axis or 4 axis BOB
    1 uc100 usb
    1 2.2kw spindle with vfd , configured for 110 input single phase, 220
    output 3 phase
    a licensed copy of mach3
