Brush less servo
Discussion in 'CNC Mills/Routers' started by future_cncist, Mar 16, 2015.
  1. future_cncist
    GrayUK likes this.
  2. GrayUK
    Clearpath - Stuff dreams are made of!!!
    Still I`ve made a note.
    Gray
  3. Nick W
    Nick W Well-Known
    I'm going to buy one for a work project. So cool.
    GrayUK likes this.
  4. GrayUK
    Nick
    Keep me posted please.
    Gray
  5. Nick W
    Nick W Well-Known
    Gray,
    maybe I should get a few extras...
  6. GrayUK
    I`m interested in the electrics you are going to need.
    And generally how it will work with servos.
    Look good though - don`t they. :thumbsup:
    The best I could do would be by one each month! :(
    They look like a good established company.
    I reckon Hytech will be watching closely too! :D
    Gray
    future_cncist likes this.
  7. future_cncist
  8. Gerry
    Gerry New
    Their "Clearpath SD" motors would be the obvious choice for CNC applications, since they would interface directly to the normal step & direction signals that stepper drivers use. They recommend a 75VDC linear unregulated power supply, but claim they are operational at only 24VDC.
    Their claim to be able to handle 150:1 inertia mismatch is most impressive, if real... probably not applicable to belt drive systems.
    And then there's this: "Teknic products are only available to volume OEM clients."
  9. Nick W
    Nick W Well-Known
    The drivers are included on the Clearpath models.
  10. future_cncist
    Justin time
    Brush less = no internal arcing . much quieter operation with higher efficiency .
    Superior in design and performance .
    In a word > quality .
  11. cnc machinest phil
    Has anyone figured out how to wire a clearpath sd to arduino using grbl. I assume you have to redo the config.h to allow for the differences in the wires and pin callouts. I am finishing up changing from steppers to servos but have not found any info on wiring except for a tutorial from Teknik that doesn't really apply to cnc gcode on an arduino.
  12. David the swarfer
    You only need 3 wires from arduino to each clearpath, ground, step, direction.
    Optionally you can also wire in the 'stepper enable' pin. Note that if you disable the drivers the motors will move freely and you will have to HOME after re-enabling.
  13. cnc machinest phil
    What controller are you going to use? I would be interested in how to wire it up etc.
