bOX
Discussion in 'CNC Mills/Routers' started by Pendragon, Jul 26, 2014.
  1. Pendragon
    Pendragon New
    Pendragon published a new build:
  2. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Pendragon,
    Welcome - I look forward to following your build :thumbsup:
    Tweakie.
  3. Seul Kee
    Seul Kee New
    I like the name 'bOX'!
  4. Duane
    Duane New
    Hi Pendragon
    Looks like we are using the same electronics. I'm also hoping to get away with open source software too.
    I have many competing priorities at the moment so while I think I have all the parts I need (except a bench), I haven't made a whole lot of progress.
    Good luck with your build.
  5. Pendragon
    Pendragon New
    Thank a lot for the encouragements. Electronic is working pretty well for the moment. But it doesn't move any router for the moment. I just received most of the hardware, including the KRESS router 1050 FM 1. My rails also arrived. Tomorrow I will cut them to the right size.
    The big part is he plate cut of. I found a fablab in the area, will take contact with them, they have a CNC...
  6. Franco Ponticelli
    The deltabot group (https://groups.google.com/forum/#!forum/deltabot) started a very nice initiative. Members can receive the printed parts to build a Kossel Mini if they pledge to print and send those for free to other members.
    My OX is basically complete but I've not tried yet to mill aluminum.
  7. Mark Carew
  8. Franco Ponticelli
    The concept is fantastic and the UI very very good. I experience a few rough edges but I am sure they will be addressed. Totally recommended.
  9. John Lauer
    Hi Franco, let me know what errors/rough edges. This is a new app so looking for community feedback.
  10. Franco Ponticelli
    As said nothing major but here are a few things I found out:
    • Can't find an easy way to regulate the feedrate in joggle mode (I suspect it is hardcoded to F200 ?).
    • Sometimes when I load a design it doesn't load it in the preview ... not sure exactly when that happens so I will search for a reproducible pattern.
    • When resetting the tinyg the connection is obviously lost but then it is not restored and I have to refresh the page to make it work.
    Keep up the amazing work!
  11. John Lauer
    • Jogging is now G0 commands, so feedrate is the max you have your machine set to.
    • Your design likely had spaces after XYZ coords. That's fixed now.
    • TinyG reconnect should be good in Serial Port JSON Server 1.6 published yesterday.
    Franco Ponticelli likes this.
  12. Franco Ponticelli
    That is awesome, I will try first thing tomorrow. Thanks!
