Blue Loctite
Discussion in 'General Talk' started by Wip, Jan 17, 2019.
  1. Wip
    Wip New
    Hello All,
    I don't think this needs an entire thread but just a quick question...
    Should blue Loctite be used on the various bolts holding the machine together? (Specifically, about to build a LEAD CNC 1010)
    Particularly on the set-screws on the NEMA motor shaft and lead screw...but also pretty much all the other bolts as well. (I have a background building R.C. helicopters and blue Loctite was your friend in that hobby - this is my first CNC build though).
    Thanks,
    Don
  2. Giarc
    I used it on everything but the screws with nylock nuts.
    Gary Caruso likes this.
  3. Wip
    Wip New
    Thanks Giarc, I figure it can’t hurt.
  4. Christian James
    Christian James Journeyman
    Is blue loctite the permanent stuff?
  5. Wip
    Wip New
    No, red is the permanent...
    I went ahead and used blue on most of the bolts.
  6. Rendermandan
    Rendermandan Well-Known
    Be aware, you will get some galvanic corrosion from the steel screws that tap into aluminum. From my experience, the screws that hold the end plates on C-beams will get "Stuck" on and require a little more force to break loose. Usually a Pop will happen you can smell a funny odor from it. Not sure what that's called. I've had to take mine apart a lot of times for adjustments, wheel replacements, upgrades etc.
    In reality, it would be better to use Anti-seize on them.
    The screws to T-nuts don't have this problem as they are both steel.
    GrayUK likes this.
