BlackBox X32 - Step/Dir Output?
Discussion in 'Controller Boards' started by Awestruck, Nov 15, 2022.
  1. Awestruck
    Awestruck New
    For the original BlackBox, I believe there was no step/dir output.
    I've glanced through the docs on the new BlackBox X32, and I wasn't seeing a way to get just step/dir, so I thought I'd ask if there is one. I like the idea of the X32, and I like the idea of servos, something like Teknic's Clearpath for a potential machine build I'm looking into. With the Clearpath they would take a step/dir input. BBX32 just seems like a simple system, well packaged.
    Correct, BlackBox X32 is just an evolution of the BlackBox family, so the old familiar values like simple to setup, plug and play, and all-inclusive still applies as it did before.
    For the adventurous hacker the dir/step pins have always been available on a the interboard header, even labelled - you can tap the signals off there by soldering to the back side of the connectors
  3. Awestruck
    Awestruck New
    Ohhh - yes I love the simple aspect.
    Do you happen to have a picture of board and where the signals are? I'm certainly done my fair share of advanced modifications.
    Checkout the old 4X assembly instructions docs:blackbox-4x:assemblyinstructions [OpenBuilds Documentation] (back from when BlackBox was still a kit)
    The large pin header between the Brains and the Muscle boards carry the signals to the stepper drivers down below. Headers are nicely shown in Step 4, flatter topdown view in Step 7 shows the labelling next to the pins better
  5. Awestruck
    Awestruck New
    Very helpful. I see them clearly and understand the assembly better now. I forgot that this used to be a kit. So much progress!
  6. WOPR73
    WOPR73 New
    Is the x4 able to be swapped out with the x32? Or do you need to change the wiring in someway?
    Depends what you had hooked up, minor changes around Toolhead connectors (more flexibility)
    See docs.openbuilds.com/blackbox
  8. WOPR73
    WOPR73 New
    It would be nice to have a comparison chart side by side detailing all changes such as processor, memory, port types, Wi-Fi band, pin outs, etc; I have to go back and look at build instructions of the x32 and setup instructions to get most of the information. But, it is still not 100% clear.
  9. Peter Van Der Walt
    See docs:blackbox-x32:layout [OpenBuilds Documentation]
