Blackbox post processor Fusion 360 (cooling before spindle)
Discussion in 'CAM' started by Touma02, Jun 8, 2020.
  1. Touma02
    Touma02 New
    I would like to know if it's possible to set M8 position before S24000 M3 in post processor fusion 360 blackbox ?
    Here code generated by post processor fusion360 blackbox
    G90
    G53 G0 Z-10
    G54
    S24000 M3
    G4 P8.
    M8
    thank you
    To change the order you'd have to edit the Post processor
  3. Touma02
    Touma02 New
    I change in the config post processor in fusion 360 and all work well :) thanks
  4. Touma02
    Touma02 New
    I have to install post processor in local ? because i think when i stop fusion et start fusion it gets crushed
    Edit it locally, rename it (update description etc in the file too so you which is yours) then upload it again like you did to install it initially
