Blackbox Faults as soon as I apply power.
Discussion in 'Controller Boards' started by pugslypoo, Mar 6, 2019.
  1. pugslypoo
    pugslypoo New
    Ok, so here is the deal, I received my black box a few days ago and finally got around to assembling it. Where I apply 24v power, I immediatly get faults on the z and y2 lights just below the potentiometers. I have not plugged in any nema 23 steppers yet, is this normal or did I maybe get a bunk board? Any help would be much appreciated.
    That would not count as expected behaviour. Hit up http://support.openbuilds.com/support/home so they can sort it out for you
    1) Do adjust the current down and see if it makes a difference
    2) Do wire up motors, maybe the fault clears
  3. pugslypoo
    pugslypoo New
    I did, both, no cigar... :(
  4. pugslypoo
    pugslypoo New
    Two of the steppers seems to function as expected but the other two no go from the beginning, I think I might have just got a bunk Driver board. Super bummed, hopefully open builds will quickly remedy this.
    FAULT led lights only on overtemp, or overcurrent.
    :) While you wait for the store - mind taking a peak at the board for any obvious shorts around those two?
  6. pugslypoo
    pugslypoo New
    Looks good from here. Store has made contact with you, as well as a PM from me :)
  8. pugslypoo
    pugslypoo New
    Wow, you guys are super on top of things, thanks so much for the great support! really appreciated! Screen Shot 2019-03-06 at 1.41.08 PM.png
