Blackbox and shielded cable grounding
Discussion in 'Controller Boards' started by Nametag, Nov 29, 2020.
  1. Nametag
    Nametag New
    I am planning on using shielded cable for my stepper motors, but I don't see a point on the Blackbox controller for grounding the shielding. From my understanding, shielded cable is not very effective unless it's grounded.
    Is there an area on the controller where I can ground the shielding?
    Thanks!
    Not grounded... Earthed. In a star config, to a solid earth spike or copper pipe into the earth outside or into the shop floor, through the slab
    Alex Chambers likes this.
  3. Nametag
    Nametag New
    Thanks for the reply
    Thanks for the reply. I had seen in a build video that the shielding was being earthed through the ground on the controller (demon controller). I don't have an earth near my garage.
    Would I be better off using non-shielded cable for the stepper motors and limit switches, and only shielding the motor cable to the vfd?
    See docs:blackbox:faq-emi [OpenBuilds Documentation] and in particular the extra link at the bottom - goldmine of into there
    basically, shield the VFD/Spindle rather than trying to protect everything else from it.
    #4 Peter Van Der Walt, Nov 29, 2020
    Nametag likes this.
