BlackBox and Nema 23 High Torque
Discussion in 'Controller Boards' started by Hellsbellsidaho, Oct 5, 2019.
  1. Hellsbellsidaho
    Can Nema 23 High Torque Stepper motors be used with the Blackbox?
    Confirming yes. BlackBox was designed to cater to them, with 4A peak, 3.2A RMS Max drivers onboard (High Torque motors are 3.0A)
  4. TerryOx
    TerryOx Well-Known
    (C-Beam XL with NEMA 23 High Torque Steppers, Blackbox controller, and Mean Well LRS-350-24 power supply)
    I am now attempting to connect the NEMA 23 High Torque Steppers to my new Blackbox controller. It appears to me that the color code may be different from the typical Red Blue Green Yellow. The NEMA 23 High Torque Steppers are no longer listed in the Parts Store, so I am still looking for the wiring convention. Multimeter shows Red and Green are a pair. Blue and Yellow also. Anyone else have this combination?
  6. TerryOx
    TerryOx Well-Known
    Thank you. There it is! You never sleep!
    Up and running again.
