Black Box Coolant output
Discussion in 'Controller Boards' started by JaS, Nov 16, 2021.
  1. JaS
    JaS New
    Hi I'm using an 110v air pump for air assist on my laser. I would like to control it using M8/M9 from the coolant output. I installed one of these.
    https://www.amazon.com/gp/product/B07W5YQNL9/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    Blackbox will switch the LED on the 24v side no problem, passing as a normal switch the hot from a to b, issue a M8 nothing until I touch a DVM across the A to B then the air pump starts up, on a M9 shuts it off.:) any clue what I'm missing?
    The coolant output is mosfet driven, intended to run loads as documented. A Solid State relay draws too little current, is not suitable.
  3. David the swarfer
    add a resistor to up the current draw?
  4. JaS
    JaS New
    so a 24v coil Mechanical should work then?
  5. JaS
    JaS New
    I don't think the 1/4w's in my spares bin will be big enough :)
    A 100k across the output might
  7. JaS
    JaS New
    Thanks, the 100k did it.
