Better Dust Boot
Discussion in 'CNC Mills/Routers' started by CKerv, Jun 17, 2021.
  1. CKerv
    CKerv New
    Hello. I'm looking for a adjustable depth dust boot which will connect to the z axis gantry cart, not the router. The one I'm using right now attached to the router and moves up and down with the router. When doing deep cuts, the bristles actually provide enough vertical resistance to prevent the bit from plunging to the appropriate depth.
    If any one can suggest a product or a custom build, I'd really appreciate it!
    Thanks!
  2. Torin3
    Torin3 Well-Known
    Something like this?
  3. CKerv
    CKerv New
    Yes! That thing is sweet. Although, I don't need anything that intense :) Looking for something manually adjustable which could bolt onto extrusion rail.
  4. Rick 2.0
    The basis for what you are seeking was brought to popularity with a Kickstarter campaign several years ago. Winston gives a good explanation below.
    A similar concept can be found here:
    There is a simpler version where the side plates have vertical slots in them for thumb screws that go directly into t-nuts in the V-slot but I haven't been able to put my finger on it. If I come across it I'll post.
    CKerv likes this.
