Best way to cut paper?
Discussion in 'General Talk' started by Chandra Saran, Oct 22, 2015.
Tags:
  1. Chandra Saran
    Hi Folks,
    Can anyone share their thoughts on building a paper cutter? I want to cut vinyl paper 0.2mm ( Peel and Stick ).
    Paper would cut in 3 inches x 8 feet strips.
    Can you give us a better idea of where you are headed with this. Are you wanting an 8' flat bed to where a drag knife could be used? Are you wanting to do this cutting on a roll-to-roll setup? How wide do you need for the initial roll?
  3. Chandra Saran
    Hi Rick,
    Thanks for responding.
    Yes , a 8 foot flatbed with a drag knife is exactly what I would want.
    Printed 2mm Vinyl ( 17 feet by 8 feet ) will be fed through a roller.
    Each cut will have to be 3 inches wide. Total around 41 pieces and I will be doing 6 sheets in total so a fair amount of cutting.
    I have seen different drag knives on the Internet and if you have a recommendation I would like to know?
    As per the flat bed build, would you recommend the V Cut series or C? And what kind of a slider assembly? There seem to be a few and not having any experience don't know the best way to start.
    Appreciate your thoughts.
    Chandra.
  4. Rick 2.0
    Suggestion using a simple parallel rail system mounted to a sheet of plywood with multiple blade holders set at 3" spacing along a sliding crossbar. You would need to rough cut a sheet 36" wide from the mother roll but the setup would yield eleven 3" strips in a single effort leaving 1.5" of scrap each side. The system shown is just a rough concept. You will need springs wedged into the front of the blade mounts to maintain pressure and you will also probably want a parallel wiring system to keep the crossbar square. The blade holders shown are a rough concept made with aluminum angle but if you have access to a 3D printer, you should be able to create a much simpler system.
    While this concept could easily be modified to where you didn't have to pre-cut the sheets and thus waste could be eliminated, it would require a rather substantial aluminum tube framework which would greatly increase the overall cost.
  5. Chandra Saran
    Rick,
    This looks fantastic! I will start with this and keep you in the loop on the progress.
    Thanks a bunch.
    Chandra.
