Best Router bits?
Discussion in 'General Talk' started by jeffmorris, May 25, 2019.
  1. jeffmorris
    jeffmorris Journeyman
    Who makes the best router bits? I think that router bits from Home Depot are not good.
  2. Colin Mccourt
    Colin Mccourt Journeyman
    Personally I would say from a novice point of view that branded bits would be better given a perhaps better manufacturing quality both in tolerances and raw material used..which commands a higher price because of production costs...Cheaper bits may be inferior but at a price point any novice can afford given he or she is not used to parameters straight away therefore it doesn't matter if you break a few in the process. Me personally the only branded bits I have I ordered with the machine and for the limited cutting I have done with them they are better. I am using cheap Chinese bits presently until such time I'm learned enough to merit using them..that day is far off yet lol..
    But in the defence of cheap Chinese bits. There are adequate up to a point...
  3. jeffmorris
    The router bits appeared to be burnt and the cuts are usually "rough". My shop teacher refused to buy me new router bits. The Porter Cable 690 router motor doesn't have speed controller.
  4. Colin Mccourt
    I think there layeth part of the problem @jeffmorris
    If you are burning bits, your Feedrate is too low. Beginners tend to be too conservative, you can take heavier cuts. In fact, you need to. Big chips pull heat out of the bits. Dont make dust. Make chips
    Joe Santarsiero likes this.
  6. ssbxfire
    ssbxfire New
    Best bits is so subjective. It just depends on what you are looking for and what is loaded the most often for the cut. I use Whiteside, Yonico and Amana
  7. ljvb
    ljvb Well-Known
    I use Whiteside as well, they are reasonably priced, not too expensive, but not cheap. I have been using their bits for non CNC based routing for ages.
  8. Colin Mccourt
    I have only one expensive bit and it's a Whiteside 25mm surfacing bit for my spoilerboard..great bit does a mighty fine job
  9. Alex Chambers
    Depends what you are cutting - I found that cutting mdf or chipboard branded bits don't last significantly longer than cheaper ones - as soon as resin from the glue builds up on the cutting edge it rapidly overheats and the keenness of the edge is lost before you realise it's happening.
    Another common beginner mistake is to use too high a spindle speed - as @Peter Van Der Walt said - make chips.
    Alex
    MFCarew and Peter Van Der Walt like this.
    Or a too low feedrate, too shallow depth of cut. Chips pull the heat out of the bits.
    Its less science, cost and brands... Than just getting in there, with some cheapies while you Learn. The experience is worth way more than expensive bits. Oh and wear eye protection. Flying pieces of carbide move like a bullet
  11. jeffmorris
    The CNC router at the program for mentally handicapped people doesn't have spindle speed controller. It uses Porter Cable 690 router motor. Any suggestions?
  12. Rick 2.0
    Put out the word in the local facebook community seeking a donation. Somebody may just have a variable speed shelf ornament they'd be willing to part with if it's going to a good cause.
  13. Peter Van Der Walt
    Maybe even try your luck with OpenBuilds Fair Share Give Back Program
    (tell the story, share the cause who knows...)
    MFCarew and Anthony Bolgar like this.
  14. RV6APilot
    RV6APilot Well-Known
    I purchased a set of end mills from Harbor Freight for $75. Might not be the best but they are good enough to play with
    and if I break one it doesn't cost me $50/end mill.
    Titanium Nitride Coated End Mill Set 20 Pc
  15. Joe Santarsiero
    Joe Santarsiero OB addict
    toolstoday has good tools if you can afford them. Amazon is hit or miss, but mostly decent. I have two CMT vbits that are pretty good and a couple of good upcuts from Amazon.
