Belts vs TR rod
Discussion in '3D printers' started by Barry Danks, Jul 13, 2017.
  1. Barry Danks
    Barry Danks Well-Known
    What are the advantages/disadvantages using TR8 over belts for the x and y axes?
    Power and resolution. With each turn of the stepper, screws move the carriage 8mm and GT3 pulleys/belts move 60mm. So when you break that down into fractions of motor steps there is a much finer resolution with screws. Screws also have better mechanical advantage and thus offer more power. From the other side however, belts offer more speed which is fine with softer materials. Which to go with is largely determined by what material you are cutting and what resolution you require. For aluminum
  3. Barry Danks
    Advantages/disadvantages on a 3D printer. I never use belts on a CNC
  4. Rick 2.0
    Sorry, I just read the new post listing and didn't notice what section this was under. o_O
    But the same applies. Belts offer speed at the expense of resolution. They also offer more configuration possibilities.
  5. Barry Danks
    Rick
    Dont really know how this post got duplicated, but can you delete the other one please
