Belt and Pinion with Solid V Wheel?
Discussion in 'General Talk' started by raykholo, Jul 7, 2014.
  1. raykholo
    raykholo New
    The belt and pinion concept, where the GT2 belt sits flush with the extrusion is shown using the Dual V wheel. Has anyone made it using Solid V wheels? I wonder if the hollow portion of the dual V wheel plays a role, such as keeping the belt aligned with the slot of the extrusion. Alternatively, the tension of the belt could also keep it straight, so I think solid could work. Has anyone tried?
  2. andrew
    andrew New
    Yep. Solid wheels work best.
  3. Mark Carew
    On the belt and pinion system I use the solid V wheel as well.
  4. raykholo
    raykholo New
    Awesome. Thank you both.
    I just put up a new post in the concepts and ideas section that I believe you both will enjoy reading.
