bCNC and the Raspberry Pi
Discussion in 'Control Software' started by Sonny Jeon, Aug 13, 2015.
  1. wiremonkey
    Thanks for the responses. I ended up installing Raspian and following the bCNC instructions here: bCNC
    It was pretty straight forward, but often times with linux versions one has to update after installing something in order to get it to work. And Google is indeed your best friend if you run into a snag or two.
    Cheers,
    Tyler
  2. Jdog
    Jdog New
    Yes — thanks for the responses regarding BCNC links and the new OpenControl option. Appreciate the forum support.
  3. Mike Fitzi
    Hi guys. I have a couple odd things...
    Installed bCNC on Raspberry pi. Works great. The 2 issues I have are:
    1- cannot see a tool's button in order to change units to inch
    2- TOOLS button isn't in tool bar to edit unit setting from there.
    Anyone else having this issue?
  4. sharmstr
