aviation connectors
Discussion in 'CNC Mills/Routers' started by mikememmi, Nov 25, 2017.
  1. mikememmi
    mikememmi New
    hello, these are cool but are they worth the effort. i am having a very hard time soldering to these little stubs. i have ordered some jst connectors and i am going to try that (4pin - 2.5 mm space). i looked at the deutsch connectors but they were way to expensive. is there something else out there that i should look at?
  2. viljami
    viljami New
    I used XLR connectors, those things that are used in Microphones and other sound equipment. You can buy those with different amount of pins and they are easy enough to solder.
    I got myself 6 pin ones so I can connect each axises stepper and limit switches with a single plug. My electronics are not quite ready yet so I have yet to see if I get interference problems because of that.
  3. mikememmi
    mikememmi New
    hi viljami, i looked at those. the ones that i saw all had the same small posts as the aviation plugs. it's a shame that you can't just get 18 awg microphone cables. i would make sure that those xlr connectors can handle the power. my motors are 2.8 amps. thanks
  4. viljami
    viljami New
    My 6 pin XLR connectors are rated 7.5A per contact which should be more than good enough. They are frequently used for large speakers as well which draw a lot power.
    You could also look up Speakon connectors / cables which are specifically meant for large speaker systems.
  5. mikememmi
    mikememmi New
    GrayUK likes this.
  6. GrayUK
    I just checked them out on UK Ebay. They look pretty good. :thumbsup:
    Has anyone else has used them I wonder?
    I would be interested to know.
    Gray
  7. Joe Santarsiero
    Joe Santarsiero OB addict
    6337 solder makes life a lot easier over 6040 solder.
    dddman and GrayUK like this.
