Availability of 57mm Spindle Mounts
Discussion in 'CNC Mills/Routers' started by Ronald4418, Nov 4, 2017.
  1. Ronald4418
    Ronald4418 Well-Known
    Does anyone know where I can purchase a Spindle mount for use on the C-Beam XL I am finishing up? I have a 57mm Air-Cooled 600W ER-16 Spindle. Though I could cobble up something that should get me through the milling of a proper mounting plate that I can attach to the Z-Axis Plate. I would sooner not lose the space involved in using such a mount. I looked at the Quiet Cut Spindle Mount available at www.inventables.com, but it only mounts on one end.
  2. linuxluser
    Any luck? I have the same issue ... :(
  3. Ronald4418
    It looks like I am going to have to design a mount and will post it once I get it figured out. I am going to try and create one that is magnetically attached so that it is a quick change mount so that I can swap it out to place my 7W Laser in its place. I'll post it once I am done.
