Aspire - Open contour
Discussion in 'CAM' started by Benjamin Vg, Nov 17, 2022.
  1. Benjamin Vg
    Benjamin Vg Well-Known
    Hello;
    I am a newbie with Aspire and I need to cut the countour of my shape:
    But as you can see it is sliced with multiple lines and it always complain about the open contours. Basically it say that if I want to cut in a simple contour I need to join it first with the countour tool. (sorry the screenshot is in french)
    So for the moment it is doing something like this but I don't want the inside cuts. upload_2022-11-17_12-55-36.png
    When I try to join two contours it is doing some crapy stuffs like :
    I have also tries to edit the nodes but is already looks joined:
    Do you have an idea for me please?
    REgards,
    This might help out
  3. Benjamin Vg
    Well except if I missed something in the video, it didn't explain how to do the extenral cut but he explain how to vcarve on the open vector it isn't what I need to do?
    But still thank you for the begin of response :)
    Sorry!
  5. Christian James
    Christian James Journeyman
    You can delete the "inside" lines, then select the outside profile you wanted and create a tool path. Once your profile toolpath is created, you can then click "edit", "undo", to restore the original drawing.
    Giarc likes this.
