Any tips for getting bearings and lock collars on 8mm acme lead screws?
Discussion in 'General Talk' started by Grumpy Burton, Sep 5, 2015.
  1. Grumpy Burton
    Bought an actuator kit from makerstore in australia and I'm having trouble getting the bearings and lock collars on 8mm acme lead screws.
    Any tips?
    Thanks,
  2. blahh
    blahh New
    Using some emery paper lightly sand the ends up to about 20mm. I usually put the lead screw in a drill and hold the emery paper around the screw. A light sand is enough to allow the bearings to slide on.
    Joe Santarsiero likes this.
  3. Grumpy Burton
    thanks. I'll give that a go
  4. Grumpy Burton
    worked a treat! thanks
  5. DarkAlchemist
    DarkAlchemist Well-Known
    Yep, 8mm inside an 8mm would be a chore to smash in so 220 grit sand paper works as well and I like the idea of putting it into a drill that way it doesn't get more sanding in a spot to cause a side.
  • About Us
    [email protected]
  • Follow us on Instagram
  • Like us on Facebook
    Donate to Open Source
