anti-backlash hard to turn
Discussion in 'CNC Mills/Routers' started by gazingm42, Feb 25, 2017.
  1. gazingm42
    gazingm42 New
    So I having issues with the anti backlash being hard to move with my hand on the Z axis. The Y and X which
    don't have the anti backlasth move fine.
    So with the z together it very difficult or impossible to turn by hand. I backed of the set screw and made
    several tests.
    Open to ideas.
  2. dddman
    dddman Journeyman
    I've seen that too, I also wonder if it's possible to save the nut...
  3. gazingm42
    gazingm42 New
    I thinking of use twobof the nut blocks vs this anti backlash. Seems to be much smoother.
  4. Rick 2.0
    A suggestion with the regular nut blocks when they are too tight is to chuck the screw in a drill and run the nut up and down a few times. May work, if not you might send a request for replacement to the shop as it sounds like a poorly manufactured nut.
  5. gazingm42
    gazingm42 New
    Good Idea. I seems the top part or the thinner part works smothly. But the lower half or larger section is very tight.. I will send them a email ...
