Acro plates STEP files
Discussion in 'CAD' started by Lucas J, Aug 26, 2020.
  1. Lucas J
    Lucas J New
    Hi everyone,
    I'm looking for the STEP files of the ACRO plates to draw a complete ACRO system on Fusion 360. Can't do anything accurate with the sketchup files !
    Thanks !
  2. JustinTime
    JustinTime Journeyman
    Did you try to import the parts as .stl files into Fusion? I do it all the time and then rework them.
  3. Lucas J
    Lucas J New
    Hi Justin,
    My current method is to import them as .stl, display their dimensions through a drawing and then creating the new design i will use. All this is quite time consuming obviously.
    The issue is that the sketchup files provided are 10:1 scale, so I can't really rework them straight. I always need to re-design them from scratch.
  4. JustinTime
    There is a way to fix this. It may take a few steps but it's not a big deal.
    Import the file into a new workplace. Turn off history. Convert from mesh to Brap (or whatever it is called). Go to the 'scale' option, select the part and enter 0.1 in the input box. Hit return and the part is now the correct size. You can now save it and then import it to your main worksheet.
  5. Lucas J
    Lucas J New
    Yeah that's the way I did, I needed nevertheless to create a new body to have the right functional properties to create joints between parts.
    Thanks for your time JustinTime ;)
  6. Christian James
    Christian James Journeyman
    Have you tried Netfabb? You can import STL files then scale them.
  7. Lucas J
    Lucas J New
    I archived doing it with fusion 360 using the scale tool once I re-designed the parts as new bodies.
  8. BhavikD05
    BhavikD05 New
    Where are the files for the ACRO Plate Sets? I can't find them anywhere.
  9. Giarc
    All OpenBuilds parts are available at the 3d warehouse in Sketchup.
  10. BhavikD05
    BhavikD05 New
    From my understanding these aren't STEP files though correct?
  11. Giarc
    No. Openbuilds designs their parts using SketchUp I believe. There are also other CAD types. The person that made the .step files did so before there was an Acro. You can export the plate you want as an .stl and open it in whatever CAD you are using. If using Fusion 360 convert the mesh to a brep and you have the plate that can be modified, or "project" the plate to a brand new drawing.
    BhavikD05 likes this.
  12. BhavikD05
    BhavikD05 New
    Great thank you so much!
  13. BhavikD05
    BhavikD05 New
    Sorry for some reason when I go to the Sketchup Library I can only download the Sketchup part. There is no format for me to export as a .stl
  14. Peter Van Der Walt
