Accuracy Measurements for Nema 23 High Torque Series
Discussion in 'Motors' started by Outright, Apr 20, 2019.
  1. Outright
    Outright New
    Hi everyone,
    This is my first time posting here and I had some questions about accuracy measurements for the Nema 23 High Torque series. I wanted a belt driven system for a couple different axes. For my Y-axis I wanted two motors to be able to pull a 97.9 N payload and my X-axis to pull a payload of 30.3 N. I want to reach a resolution of 0.1 mm and an accuracy of 0.2 mm in both axes. I read up on the accuracy measurements for the motor and it had a resolution of 1.8 degrees +- 5%. I am assuming that this would be a +- of 0.09 degrees? I also read Rob's actuator testing, but the accuracy readings there do not include with a payload, does anyone have insight on how the payload will affect the accuracy measurements?
    Any help would be appreciated, thank you guys so much.
