about to start my c-beam build
Discussion in 'CNC Mills/Routers' started by Elhanan, Jun 23, 2017.
Tags:
  1. Elhanan
    Elhanan New
    hi... so i'm about to start my c-beam build soon, and based on my tevo experience, i'm assuming it won't be easy, i'll be basing my build on this video
    so i was wondering any general tips i should know about ? (for example on tevo group everyone keeps saying replace the spring washers with flat ones or you'll brake the acrylic)
    but aside from that i was wondering, can i use this board as the table and waste board he's talking about on 37:10 ? it's 1.8 and not 1.3 cm
    further more, why use 30.5x30.5 cm when the build area is 35x28 cm ?
    The only things you really need to check with this system are to make sure the ends of the extrusions are cut square and that the base cross members are not longer than the X-axis C-beam. The extrusions are cut on the fly at the factory and should not be assumed to be perfect. There are several threads and posts on the subject. You may find reading back through the comments in the C-beam threads to be beneficial.
  3. Elhanan
    Elhanan New
    and the wood,? i've been reading around about wood choices for spoiler boards and it seems MDF is always preferable.
  4. Rick 2.0
    The image you provided is not displaying on my computer so I'm not sure what you are referencing but MDF is pretty much the crowd favorite as it cuts cleanly. As for board size I can't answer as I haven't built one of these.
  5. MaryD
    MaryD OpenBuilds Team
    Let us know how your build goes!
