A complete table from V slot?
Discussion in 'General Talk' started by Shannon Jardine, Oct 31, 2015.
  1. Shannon Jardine
    Hello everyone. I am new to building with V slot or other extrusion. I have used some extrusion on smaller projects. I am making sure before I continue with a large table that I can build the complete table from V-slot or do I need to build a steel frame table and use the V-slot as the axis frame?
    Table size 3000 x 1800 MM. This is a large table and will have light material (Textiles) for a laser cutter.
    Any help or guidance would be great.
    Shannon
  2. Ronald van Arkel
    Hello Shannon,
    Use indeed a steel frame to mount the V-Slot on. Steel angle would be perfect so you can perforate and screw the V-Slot to it. I've seen projects that are using 2 V-Slots of 1500mm for the Y-axis and 1 V-Slot of 1500mm for the X-axis. I've never tried to get it the X-axis to 1800mm.
    -Ronald
  3. Shannon Jardine
    Thanks for the reply. I am thinking about using 80/20 extrusion for base table. Then I will have a rail to bolt the V-slot to. Checking on cost. If this is cost prohibited then I will break out the welder and make a table.
    Thanks Shannon
  4. Ronald van Arkel
    I've made tables for plasma cutting and they use 2x 80*20*1500mm and 2x 60*20*1500mm (one cut in half) put together like this:
    I use Cast Corner Brackets (made plat on the sides) , double t-nuts and end-plates to get a nice and stable rail. Make sure you cut the ends clean/straight when putting V-Slot together like that ;).
    -Ronald
  5. Shannon Jardine
    Thanks for the pic. This gives me some ideas. So you have a belt and pinion set up. Do you think that will still work for a longer table? I like the idea of bolting the table together. I was thinking about completely welding it.
  6. Ronald van Arkel
    I would say it might work but never tested it. Just make sure the belt tension is the same at both sides; easy to do with a a hanging scale so you can see how much pounds/kilos you pull. A 2.5-3.5W 405-445nm laser should be enough to cut normal fabric and cow leather.
    -Ronald
