7I80DB Ethernet Anything I/O card from http://www.mesanet.com
Discussion in 'Interfaces' started by Public Do Omens, Jan 31, 2014.
  1. Public Do Omens
    Guest Builder
    7i80dbcolo.png Quote
    " The MESA 7I80DB is a low cost, general purpose, FPGA based programmable I/O card with 100 BaseT Ethernet host connection. The 7I80DB that uses standard parallel port pinouts and connectors for compatibilty with most parallel port interfaced motion control / CNC breakout cards/ multi axis step motor drives, allowing a motion control performance boost while retaining a reliable real time Ethernet interface. Unlike the parallel port that the 7I80DB replaces, each I/O bit has individually programmable direction and function. The 7I80DB has a simplified UDP host data transfer system that allows operation in real time if required and compability with standard networks for non-real time applications. Dual FPGA configuration EEPROMs allow simple recovery from programming mistakes. The 7I80DB provides 68 I/O bits (17 per connector) All I/O bits are 5V tolerant and have pullup resistors. A power source option allows the 7I80DB to supply 5V power to breakout boards if desired. This 5V power is protected by a PTC. Firmware modules are provided for hardware step generation, quadrature encoder counting, PWM generation, digital I/O, Smart Serial remote I/O, BISS, SSI, SPI, UART interfaces and more. Configurations are available that are compatible with common breakout cards and multi axis step motor drives like the Gecko G540. All motion control firmware is open source and easily modified to support new functions or different mixes of functions. "
