+6 % dimensional error with SVG not at correct size in OpenCam
Discussion in 'CAM' started by Kevl4r, Sep 13, 2021.
  1. Kevl4r
    Kevl4r New
    Hi there,
    I am encountering an issue in Open Cam.
    I have this SVG that has a width of 978 mm, made with Inkscape. (purple rectangle below for the width)
    To be sure I have rechecked the dimension in other softwares :
    In Blender :
    In LightBurn : (See the Width below)
    In all 3 softwares the width is 978 mm, so I am thinking that the file is correct size wise.
    However when I drop the file in OpenCam I get a width of 917 mm :
    Any help would be greatly appreciated.
    Thanks,
    Thomas.
  2. Kevl4r
    Kevl4r New
    To be sure I have also started a new project in Inkscape test_855.svg, that is 855 mm of width.
    when I open this file in OpenCam it changes to 801 mm of width.
    Play with your DPI settings, or use DXF (proper dimension info in the file): OpenBuilds CAM assumed DPI from the standards for different applications and versions as below. One of the disadvantages of SVGs. Its unitless (pixels * dpi to reconstruct to actual mm/inch) whereas proper CAD formats like DXF does maintain measurement units as well.
    Code:
    if (editor == "inkscape") {
        if (version > 1.0) {
          resol = 96dpi
        } else if (version > 0.91) {
          resol = 90dpi
        } else {
          resol = 96dpi
      } else if (editor == "illustrator") {
        resol = 72dpi
      } else if (editor == "Opentype.js") {
        resol = 57dpi
      } else {
        resol = 96dpi
  4. Kevl4r
    Kevl4r New
    Thanks Peter,
    changing DPI has solved the issue.
    I have tried on WIN10 / Inkscape 0.92
    I went to Extensions > Document > DPI 90 to 96
    Saved the document
    In OpenCam it has now the correct size.
    On Linux Arch / Inkscape 1.1
    works the same as in windows 10 :
    Saved the document
    #4 Kevl4r, Sep 13, 2021
    Thats a super old version of Inkscape (2017) - try to stay more up to date to avoid issues. You should be on 1.1.x Download Inkscape 1.1 | Inkscape
