4'x4' build possible?
Discussion in 'CNC Mills/Routers' started by Chad Alexander, Jan 14, 2014.
  1. Chad Alexander
    As I understand from another thread, a full 8' build is not possible based on the precision of the extrusion at those lengths. On the Ox build, it seems the limit is 4'x2'. Is this the case? Could the gantry not be expanded to a full 4' with that same design?
  2. bobt
    bobt Well-Known
    You can build a 1500mm x 1500mm with existing extrusions. Which is 59" x 59" in size.
    Bob
  3. Nick Lancaster
    Yes, I am designing around being able to build a 50x50 cut area using 1500mm rail. going to build the first one using just 1000mm rail to be sure.
