4th axis BlackBox x32
Discussion in 'CNC Mills/Routers' started by Bowbo974, Jan 11, 2023.
  1. Brent Hutchens
    Past that hurdle, to find the source of growling ball screws….
  3. kaoscreations
    Hi, sorry if I'm bringing up this thread again but I'll try to avoid opening a new one. I bought the new BlackBox x32 because I am interested in installing the 4TH axis. If I understand correctly, to do this, I should split the cable that starts from Y1 and go to the two motors, I take Y2 to motor A and then install the FW for the rotary, is that right?
    alternatively I could instead bring the y1 cable to the y1 motor, y2 to the y2 motor but split it towards A with a switch and when I need to use the switch to turn one off and turn the other on? Did I perhaps say something stupid?
    Parallel both Ys off Y1.
    4th is wired to y2
    kaoscreations likes this.
  5. kaoscreations
    perfect thanks!! by doing this could I lose power on the Y axis or is it as if it were the old blackbox that I used until yesterday (where there was essentially a divided y)? By doing this I could always keep the A axis mounted and above all move both Y and X if I'm not mistaken. Thanks again!!
    X32 has a proper 4-axes firmware yes (its a 32 bit controller running grblHAL) so not only can you leave the A-Axis connected, you can setup proper 4-axes toolpaths that not only park they Y but actually use it (proper "4-Axes" toolpaths too)
    Jerome D and kaoscreations like this.
