4th axis BlackBox x32
Discussion in 'CNC Mills/Routers' started by Bowbo974, Jan 11, 2023.
  1. Bowbo974
    Bowbo974 New
    Hello, I just received the blackbox X32 I will use it on a LEAD 1010 I would like to use it in 4th axis with rotary. I would like to know if it would be possible to connect the 2 Y axes to the Y output of the controller and keep the Y2 output for the rotary axis? thank you
    Correct. Both Y motors in parallel on Y and the 4th on Y2. Then flash the 4th axis firmware from Wizards and Tools > Firmware flashing tool
  3. Bowbo974
    Bowbo974 New
    thank you, the driver will support 2 stepper?
    Yes with ease. Two two motors on Y is more to prevent racking anyway, doesn't work very hard
  5. Bowbo974
    Bowbo974 New
    ok thanks, openbuild cam and openbuild control can handle 4th axis? Or do you have to use another software?
    You have to use something more advanced like Fusion360
  7. Giarc
    If you really want the fourth axis work to be easy, VCarve Desktop v11.5 is real easy to learn and use. But that being said, I have never tried generating CAM for a rotary in Fusion 360.
    I have hear good things about Carveco as well, but have no first hand experience.
  8. Bowbo974
    Bowbo974 New
    thank you, I have already tried fusion 360 but I have a lot of trouble taking it in hand i'm used to solidworks, but i have the student version and there's no built-in cam in this version moreover I do not believe that solodworks manages grbl I will look for vcarve, thank you
  9. Giarc
    Vcarve can be purchased at various sites, but it is also sold here in the OpenBuilds Parts Store. VCarve Desktop v11.5
    For more information on the various versions of Vectric's software, look here: V&Co - Vectric Customer Portal
    The nice thing about their software is that you can always upgrade to a more powerful version by just paying the difference in price. I went with Vcarve Desktop because I have no need to cut anything on my rotary axis longer than 24 inches. If some day I do need a larger area, I can upgrade to Vcarve pro and get credited with the price I paid for Vcarve Desktop.
    If you do go with Vcarve, this post may help you get up and running quickly. It is how I do my rotary projects. LEAD Lathe
  10. Bowbo974
    Bowbo974 New
    I have another question, as soon as I activate the limit switches, I have alarm 1 and I can't do anything
    he has to turn it off.
    I have $5=7
  11. Peter Van Der Walt
    What type of switches do you have? For ours the X32 needs $5=7
    #11 Peter Van Der Walt, Jan 16, 2023
  12. Bowbo974
    Bowbo974 New
    I have xtension limit switch
  13. Peter Van Der Walt
    Then that would be $5=7 - so that is correct
    Upon triggering an endstop, it enters Hard Limits alarm mode. The Alarm window pops up giving your a Clear Alarm button (Also available on the top toolbar if you closed the error)
    Clear the alarm, then jog out of the switch.
  14. Bowbo974
    Bowbo974 New
    I don't have a switch to activate, when I clear the alarm, it comes back in a loop and I can't do anything. at one point the red light (!) lights up at the level of the driver X
    in troubleshooting all switch works
    I deactivate the limits switch and I have no problem
  15. Peter Van Der Walt
    - I do see you are connected via Wifi - as a test - try connecting via USB - just to determine if that plays a role (if so we can dig deeper)
    - Are you running the stock 3 Axes firmware? Up to date (Flashed recently?)
    - The FAULT LED: See docs:blackbox-x32:currentadjustment [OpenBuilds Documentation] - second paragraph
  16. Bowbo974
    Bowbo974 New
    With usb is a same,
    Yes a running au stock firmware,
    OpenBuild Control flash This morning
    The fault led is on with no wire connected ( motor or switch ) when the limit switch is actived in grbl
    I try with blackbox x4 and all is good
  17. Peter Van Der Walt
    Please contact the store via Support > New ticket for that one
  18. Bowbo974
    Bowbo974 New
    I'm unlucky, it's the second time it's happened
  19. Peter Van Der Walt
    That would sound a lot less like luck - than something in motor wiring / psu / etc causing damage to the BlackBox - added a note to support team to let them work though it closer with you, help you find whats causing the damage. Prep some pictures of your motor wiring, lists of any 3rd party components in use etc - they'll be asking for more info like that to help you find the cause of the trouble. Thanks
  20. Bowbo974
    Bowbo974 New
    it would be weird if it was a connection problem, because it's an upgrade from a blackbox x4 to x32, I just reconnected the connectors. moreover, when the limit switches do not activate in grbl everything works
  21. Peter Van Der Walt
    Please continue with the store, as advised above. Thanks.
  22. Quentin Karmark
    Did you try this yet?
  23. Peter Van Der Walt
    For the BlackBox X32, that is the correct way. Y1 and Y2 on Y1 Driver, Y2 becomes the A axis
    Flash the 4-axes firmware from Wizards and Tools > Firmware flashing tool
  24. Quentin Karmark
    Sorry, I was trying to ask the OP to see if the 4th axis was ever built.
    @Bowbo974
  25. Brent Hutchens
    Is there a diagram of the wiring for this and do two wires need to be reversed for one of the y motors?
  26. Peter Van Der Walt
    No diagram yet. If its a belt drive machine with the Y motors facing each other then one motor is reversed.. If its leadscrews no reversal needed.
  27. Brent Hutchens
    ok Ive got it connected and the firmware is up and running. this is a ball screw setup. now the issue is when jogging y, one side moves before the other.
  28. David the swarfer
    disconnect the Y motors from the leadscrews and check that they move at the same time and in the correct direction.
    I suspect one of your motors is not actually running
  29. Brent Hutchens
    thank you!!! I had just fount that in one of your earlier posts. Im thinking it is at the plug. 2 wires is a tight sqweeze
  30. Peter Van Der Walt
    Doable, but can always splice further up away from the connector too. Use Wagos, 1-in-2-out lever terminals, Screw Terminals, splice connectors, whatever method you prefer
