4ftx3ft mega2560 ramps laser build help?
Discussion in 'Laser Cutters' started by kenny h, Feb 9, 2018.
  1. kenny h
    kenny h New
    okay i just started this project i have a few questions .... i am building a 2020 frame with dual yaxis stepper motors and a single x axis stepper how am i to connect 2 y axis steppers to the ramps 1.4 ? also what firmware is best for this? i currently have the newest build of skynet installed on my board. and will the z axis endstop cause me a fit not being installed ? thanks
  2. kenny h
    kenny h New
    also for now im using a 500mw blue diode laser will update to a 5w later it has a external driver with ttl
  3. MaryD
    MaryD OpenBuilds Team
    Just want to say that I can't wait to see this build!
  4. kenny h
    kenny h New
    Ill upload pics today after the mailman brings me some goodies
    MaryD likes this.
  5. kenny h
    kenny h New
    Getting started on this monster. 4ft x 3ft 10in
    MaryD likes this.
  6. kenny h
    kenny h New
    A work in progress
  7. kenny h
    kenny h New
    ok i have a problem i have solved my dual y axis problem i believe but my steppers will not move just make noise ive tried to switch the wiring around for my steppers still no change ?? sorta of a click/hum
  8. JustinTime
    JustinTime Journeyman
    If your stepper will not move but just make a hum you may want to check the amps setting. It may be too low.
  9. kenny h
    kenny h New
    I have tried turning them up and down and switching the wires .They wont even move with no load on them could it be a setting with my marlin firmware ?
  10. kenny h
    kenny h New
    well i killed my board waiting for replacement ..... im starting from scratch new board new firmware new drivers and if that dont work new power supply im using 5amp 12v psu currently do i need more than 5 amp to frive 3 stepper motors?
  11. JustinTime
    On my 3d printer, which is similar in construction, I use a computer power supply rated at 360W which is about 30A. Take away the extruder heater and you are still left with more than 10A.
  12. kenny h
    kenny h New
    Ok ty ill upgrade the psu
  13. kenny h
    kenny h New
    we got movement some firmware tweaks and finalize wiring and then testing
  14. kenny h
    kenny h New
    ok i got some wire organizing to do everything seems to function but!!!!!! i have no clue on hot to use the lasr setting in marlin my laser pin is set to 44 for ttl i have my laser wired up but it does not seem to turn on/off?
  15. kenny h
    kenny h New
    Well its alive and doing something lol
    GrayUK likes this.
  16. kenny h
    kenny h New
    now having issues with ttl control on laser but will figure it out
  17. kenny h
    kenny h New
    can someone why my machine will not auto home y axis please i uploaded my firmware
  18. kenny h
    kenny h New
  19. JustinTime
    I reassembled yesterday my 3d printer after is was in storage for months. It uses the RAMPS 1.4 board. When I finished none of the axes would home. Turned out I connected the limit switches in the wrong place. On the board there are six locations for the limit switches, two for each axis. I had put the connectors on the location for each axis rather than the first. When I changed it to the first it homed. Can it be that your y axis limit switch is also in the wrong location?
  20. kenny h
    kenny h New
    i figured it out when i used the option to lighten the firmware up it did something to my firmware i rebuilt the firmware from scratch all works now
  21. kenny h
    kenny h New
    its working fine now just have to learn how to use inkscape lol
    JustinTime likes this.
  22. kenny h
    kenny h New
    got octiprint working on my laser i will get this thing figured out someday
  23. kenny h
    kenny h New
    Striped a mini desktop pc shoved a power supply ramps and raspi inside now soldering 80 wires fun
