3D rendering not working on build 1.0.196
Discussion in 'Control Software' started by Greg McEntyre, Oct 20, 2019.
  1. Greg McEntyre
    Greetings all. Anyone else having issues with the 3D View feature on the latest update? Prior builds worked fine, only after the update did the feature stop working... just rotates an icon as it it's still working.
    We are busy debugging an issue inside the 3d viewer, so not impossible.
    - Post the gcode file for us to test here too
    - press F12 (check for errors on the Console tab inside devtools when loading a file) - Screenshot any errors please
    - Check troubleshooting tab - application diagnostics. Make sure you have nothing disabled.
    In the meantime grab an older build from github.com/OpenBuilds/OpenBuilds-CONTROL/releases if you want to get going
