2 watt JTechPhotonics Laser Combo for sale !!!
Discussion in 'Laser Cutters' started by Hytech2k, Aug 11, 2015.
  1. Hytech2k
    Hytech2k Veteran
    I'm selling off my 2 watt laser diode / driver combo.
    You get everything you see in the photo and a couple extras. I'm also including a G2 glass lens and the fan kit from JTechPhotonics for this laser. Everything is in perfect working order. I have the driver throttled down to 1.5 watts just to test the laser and not to put any real strain on it, I probably put less then 8 hours on this setup. I'm moving to a different laser so this one is no longer needed. The mount for the fan add-on will need to be reprinted on a 3D printer (original broke while trying to install) will include link to the stl and I had to cut the wire on the laser to lengthen it, i'll re-solder and heatshrink before sending..
    Here is a video of the laser in operation:
    $275.00 value, yours for only $175.00 + Shipping
  2. George M
    George M New
    Hey Gerald, a couple of questions.
    I plan to add a laser to my current CNC.
    Is this a blue laser?
    Is it focusable?
    Did you do any 3d etching with it"
    Why are you going to 6W?
    By the way, since adding the steal rails to my F-117, its been holding up well.
    George M
  3. Hytech2k
    Hytech2k Veteran
  4. Hytech2k
    Hytech2k Veteran
    Laser is not for sale any longer, I've decided to keep it for the time being to test with.
    Thanks !!
    Gerald
