2:1 reduction that can be placed any where on C-Beam
Discussion in 'General Talk' started by Ronald van Arkel, Aug 15, 2016.
  1. Ronald van Arkel
    This project is on hold but we do have something "new", just jump to this post: 2:1 reduction that can be placed any where on C-Beam
    So, this is the idea; a 2:1 reduction that can be placed any where on the C-Beam, besides that, a bearing block can be used to free up the end of the C-beam so both ends of the C-Beam are free and easier to mount on other V-Slots/C-beams.
    Some highlights:
    - 2:1 Reduction or 1:2 speed-up
    - Only one large eccentric spacer needed for adjustment (custom, not OpenBuilds part)
    - Special plate on both sides when gear reduction is implemented, one plate is needed for 1:1 or 1:2 speed-up
    - Can be used with 8mm straight rod for double drive Y-axis with single motor
    - 1040mm Acme screw can reach 990mm movement (with OpenBuilds XL gantry plate on a 1500mm C-Beam
    - 1300mm screws can reach 1220mm/4' ;)
    - Low noise, less heat, compared with spur gears
    - Stock GT3 (3GT, GT2 3mm)
    Not cheap, but we'll see how it evolves.
    Just an early picture:
    -Ronald
    #1 Ronald van Arkel, Aug 15, 2016
    Kyo and Barry Danks like this.
  2. Barry Danks
    Barry Danks Well-Known
  3. GrayUK
    It's easily done, but, I'm confused? Maybe when some more pictures turn up. (I hope!) :rolleyes:
    Gray
  4. Paul Stoller
    Paul Stoller Journeyman
    I like the iteration, getting it down to one plate is brilliant!
  5. Mark Carew
    Very cool Ronald! :thumbsup:
    Paul Stoller and Natytec like this.
  6. Brandoneous
    Awesome! You are very talented. Excellent work!
  7. Gary Caruso
    Very cool reduction, But for the acme why not just use TR8*4 instead of TR8*8? the 8*4 has 4mm of travel per turn instead of 8mm?
    Love the UHMW Rack!
    Oh and is that a new type of C-Beam on the way?
    #7 Gary Caruso, Dec 13, 2016
    Paul Stoller likes this.
