1515 - few quick questions
Discussion in 'CNC Mills/Routers' started by Timber n Thyme, May 1, 2022.
  1. Timber n Thyme
    Howdy all,
    In the last steps of completing a lead 1515 build. Bought a few extras with it, the xyz probe, the interface, ect.
    Few things im not finding in any build videos.
    1: What are you all doing for cable management for your router cable? I got the ER11. What the best way to deal with the cable and powering it.
    2: Not finding any "build videos" on the interface. No idea how to install it, configure it.
    Any help appreciated.
    Thanks.
  2. Alex Chambers
  3. Timber n Thyme
    Any other ideas out there besides the swingarm for router cable management?
    That doesn't really flow well with the config of my workspace.
  4. Christian James
    Christian James Journeyman
    Here's my simple "temporary" router cable solution (well, ok, its been temporary for 3 years!)
    It cost me a nail to hang from the roof joist. My intention is (was) to cut a small wooden pulley to loop the cable over for strain relief.
    The Cable needs sufficient slack to cover all corners of the bed that's all.. Not pretty, but if you want something simple.....
    Mark Carew and Giarc like this.
  5. Giarc
    Mine is the same way. I have it plugged in to a ceiling outlet and it just hangs down. It stays out of the way and can reach all sides.
  6. Mark Carew
    There's nothing more permanent then something temporary ;)
  7. Timber n Thyme
    Thanks guys,
    went with a swivel hook screwed into the ceiling. Seemed to be on par for modern engineering.
    Giarc and sharmstr like this.
  8. pwoody
    pwoody New
    has anyone tried running the router cable through the drag chain? there is enough slack to run the cord along the x axis and about 3/4 of the way down the y axis which means there is the potential to have a plug at that location to plug the router into. Also has anyone ever cut the cord and made the cable longer? if so did it work ok?
  9. Gary Caruso
    Don't run the stock cable through the chain with the other cables. Too much EMI
    Gary
  10. pwoody
    pwoody New
    got it! i was hoping that EMI shielding block that came on the router would be sufficient enough but was afraid i was going to get that answer. Looks like another trip to Lowes for some swing arm material!
  11. Stwspoon
    Stwspoon New
    If your router is a Makita, the “EMI shielding bulge” is actually just a plastic clip with anti-theft RFID tag inside. I took mine off to move it closer to the motor and discovered this.
