1500mm Screw Whip Solved??
Discussion in 'General Talk' started by GrayUK, May 13, 2018.
  1. GrayUK
    This is new to me, but maybe not to others. We find that longer screws are inclined to generate whip when being asked to drive at higher speeds, but take a look at this.
    Long Travel vs High Speed: Part 2
    I'm pretty sure we can throw this idea out there, and someone can come back with a cheaper but reliable design we could use.
    I really haven't given it much thought, from a practical point of view, but I like the idea!
    Any suggestions??
    Actually fairly simple. Can't really do it with TR8x8 screws due to the lack of decent AB nuts but to drill out a standard pulley, mount a dumpstercnc flanged AB lead nut inside and wedge the whole assembly between a couple thrust bearings would really not be that difficult. As far as reliability, that'll all come down to testing.
  3. JustinTime
    JustinTime Journeyman
    The hollow shaft is a great idea. You could make the lead screw almost any length and have no whip.
  4. Gary Caruso
    I like it, can do it with something like this... i can't find any with TR8*8, this one is 10x10mm which would be good too
    Non-captive stepper
  5. GrayUK
    Yeah, I'd forgotten about those. Could easily strap it under the moving bed on the Y Axis:D
    1500 Y axis sorted :thumbsup::thumbsup:
